Hydraulic pump
Peter Mack
New member
Wasleys South Australia
Hi, my 1999 cabriolet 306 roof pump will run but won’t activate the roof, I replaced a hose for the rear window and when I tried raising or lowering the roof I hear the pump run but nothing happens, it’s full of oil and everything works manually fine. Any ideas as to why. Thanks for any help
Normally need to bleed hydraulic systems
There is probably air in the line and this is just getting compressed. So nothing works :(
Don't know how the Peugeot system works but normally crack open a fitting or bleed valve to let air out.
If unsure take to mechanic as hydraulics under pressure are dangerous
You could try putting the roof trough the emergency closing and opening procedure a couple of times. That should bleed any trapped air out of the system. Should be in your owners manual if you need the instructions.
