My daughter has a 1.4 R12 and its got all the pollution stuff on it and it runs OK but... I'm sure it could run better and use less fuel with a bit of the crap removed. Any ideas where to start or should I just leave it?
Or, replace the air filter housing with one that doesn't have the heat control flap. There appear to be plenty of the simpler air filters around.The simple solution is to remove the air filter, and permanently lock wire the flap to the cold air position. Then, replace the filter, and discard the flexible heat hose (if still fitted) joining the exhaust manifold to the filter intake.
The Renault 16TS has the manually operated summer/winter flap. Works nicely. And since the R16TS filter system is designed to fit a two barrel Weber, it may even fit straight on to the R12 carby. That's only a wild guess, though, since I don't know what the top of the R12 1.4 carby looks like.KIMDEB:
Mark,
You may have seen other models of cars which have a manually operated valve on the filter, with positions marked Summer and Winter. Much more reliable, provided you remember to re-set at the appropriate time!!
Kim.
