Hi,
Please help, my 2007 Peugeot 307 1.6L diesel won’t run, it stalls below 2000rpm until its at running temp, then will idle but sounds like it's pinging. Then tends to switch to limp mode.
I’ve printed the associated error codes and they read as follows…
P1166 “Maximum rail pressure exceeded”
Associated variables:
o Engine speed: 0129 rpm
o Diesel pressure: 1757 Bar
o Diesel limited pressure 0322 Bar
o Pump output: 0 mm3/sec
o Diesel flow regulator voltage: 01000mV
P1633 “Fault inside ECU”
o Engine speed: 0000 rpm
o Air flow voltage: 051 mV
o Inlet air temperature: 212 degrees Celsius
o Gross flow injected: 000 mg/stroke
o Status of engine: Initialisation
Any suggestions would be very much appreciated.
Jon
Jon
