OK confession time - its not French - but it could be (at least for RWD French). I'm getting a noise I think from the driveline of my (new to me) Ute, up to about 70 kM/h its not there (or at least too quiet for my ancient ears to detect), but over that speed there's a 'booming' (or like incredibly rapid drum-roll) getting progressively worse until about 95 kM/h after which it appears to recede a bit. The other major factor is it disappears instantly on the overun. So if you're on cruise control it comes in and goes out dependent on slope / headwind etc.
Vehicle is RWD with non full-time 4WD, selected by rotary switch on console (must be electric servo to actually move the gears) - I haven't used 4WD at the sort of speeds listed above to see if its any different. The front hubs are 'freewheeling' so I guess the front propshaft shouldn't be rotating at all when in 2WD? Only had the veh a few months (& irritatingly test drove it only in urban surroundings no never got more than about 60kM/h ). Recently needed to go to Melbourne (ca. 900kM) in it and prior to that journey I jacked it up, checked levels on Rear axle, Front axle, gearbox, transfer case. Also hit all the greasepoints on the UJ's with generous squirt of grease (they'd probably never been done). Overall its nine years young & done under 100,000 kM, can't say the Melbourne round trip has made things noticeably worse (or better) - that might've been 'cos I had the musak turned up high enough to make my ears bleed for most of the trip
Any ideas where to look next?
Thanks,
Rob
Thanks,
Rob
