*General - Electrical contacts Handy tips.
Status
Not open for further replies.
George 1/8th
Well-known member
Melbourne, Victoria.
Handy tips.
Hi Froggies,
here are some handy tips that might be useful.
When cleaning flex connector contacts like those in a CX instrument cluster, try using a typewriter rubber . It cleans the contact without damaging the plating.
http://www.aussiefrogs.com/forum/attachment.php?attachmentid=688&stc=1
Recently when I removed the cooling system header tank I found a crack in the neck where the hose connects. Although it was not leaking it was a weak spot.
attachment.php
By using a hot soldering iron I melted the area of the crack. I clipped off some spare plastic material from the bolt hole support areas, and melted it onto the melted crack area to re-inforce the join.
attachment.php
I used the same method to repair the washer bottle as well.
Cheers...George. :cheers: :citroen:
Status
