Meant to add -- I'll most likely go with whatever drive shafts match the brake donor vehicle and then get VW joints on the other end....
Correct: There is movement of about 10mm overall or about 5mm either way.Do make sure that whatever joint you have at the transmission end is at the center of rotation of the suspension. Otherwise, I believe the up and down movement of the suspension will put up/down loads on the transmission output shafts. I think the TAV front suspension is equal length arms so that just means the joint has to be in the same plane as the upper and lower bushings. Others here may have more insight in that regard.
Wasn't following this & I just picked it up Pete & read through it ~I'm going to take a leaf out of Johns book (Ringer) and upgrade to disc. Not certain what donor yet but probably the same Holden Astra (Opel/Saturn Astra here in the US) that he used. With the extra weight of the batteries I'll feel better with improved brakes.
I'm still not decided on whether I'll keep the TA wheels -- but most likely.
Re the silentblocks -- I'm assuming they're dodgy and am planning on replacing them. I'm getting the Harbor Freight 20 ton press this weekend. I saw your post on another thread and I'm hoping mine will go smoother........
