The old retaining ring on the 306 had snapped so got a new genuine PSA one from Martin at EAI. I am having real trouble getting it to thread on properly on to the tank. When it does go it gets tight real quick but isn't putting pressure on the pump and petrol leaks at the joint. I have a good green seal in it, and it is sitting correctly.
I can't see where the thread starts on the tank, there is a larger tang on the ring that lines up with where the thread starts and I have tried starting with that at the furthermost forward part of the tank (6 o'clock position as looking from above) but still no joy. Thing is I have the same problem in my 407 as well, new ring won't go on properly, but on that it only leaks if I totally fill the tank. On the 306 it leaks when the tank is just above half full.
Steve
Steve
