My 95 306 XT has developed a fuel leak the last couple of months.It only seems to leak when the car has not been started for two days or more and it's always at the worst time to get underneath to investigate.It seems to be leaking from a metal tube under the drivers floor pan area.When it does decide to leak it leaks about a drop every two seconds.Last Sunday (not leaking)I crawled under the car to have a closer look.I noticed that one of the fuel lines (under the drivers floor pan) has a rubber sleeve around it.This rubber sleeve is about 10 cm long.I'm suspecting that this intermittant leak is from that rubber sleeve.Can anyone confirm that the sleeve is fitted from the factory to prevent the fuel lines from rubbing against each other? Or is it a previous repair on the fuel line that needs to be redone?
The car has always been on a staple diet of nothing but optimax. tongue
george
george
