Surely Google shows you how to set and check Cam Timing ........
Hi FirebladeJust checking in to see who's awake! No - really, I am about to do a rebuild of an R5A engine, and my view with rebuilds and camshafts has been "to let sleeping dogs lie" - but then I've only done vanilla rebuilds of motors in generally sound condition - just cleaning up a head, swapping out pistons and sleeves, doing big end bearings and not even touching the crank. But I a fear I am about to venture into virgin territory and this photo freaked me out 'cause I don't have any of this kit available!!! Will be giving Mr Google a workout.
Brilliant Mr Sunroof... I presume it ran well at revs?I had a constant miss at idle on my R17TS. Changed plugs, twinDCOE's, dizzy, fitted electronic points. But still a constant miss sound at idle. I had the cam reground to standard before the rebuild. So there was no reason for the miss that I could find. So made up my own degree wheel with a school protractor out of card board. Checked the top dead centre with a marked bronze welding rod. And just watched the valves or used my fingers to feel when the valves opened and closed etc. What I found was a difference in the cam grind. Normally should be 42-72-72-42. It was actually ground 42-72-72-52. Hence the exhaust stayed open longer causing the nice miss sound. Put it all back together and didn't worry about it any more. Why did the grind shop do that, who knows. But the lessson is that you don't need to spend money to do checks like that. It is'nt an F1 engine is it?
Sure runs fine once the right pedal is pressed.Brilliant Mr Sunroof... I presume it ran well at revs?
Maybe you should have got the organ grinder to do the grind and not his monkey.I think I remember you mention something about that before. Silly organ grinders
