Epic drive.
tasie C5
Active member
St Helens Tasie
After a wonderful drive over to West Australia with my grandchildren the car broke an injector hold down clamp and the injector was pushed through the injectors cover. There was no fuel leak. Looks like one side of the clamp had given way. The car now is in the small town of Ravensthorpe. I hope to find a new/used clamp his week. ANY IDEAS??? Please.
Try Ford if you can't get something sent to you from Citroen/Peugeot.
Worst case, grind down a similar clamp or have the broken clamp welded back together or built up as a get you going fix.
Be mindful of the return hoses in case any plastic joiner was cracked.
Ford calls the Citroen RHH engine the Mondeo Mk4 2.0 TDCi 163 HP.
Thanks for the tips. All new parts ordered and on their way. All 4 new ( modified) clamps to be fitted. The failed injector and seat is being replaced along with the return line and supply pipes. All parts from Peugeot/Citroen warehouse. RHH engine.
