For those who followed the thread a few months back regarding fitting Electronic ignition kits to Aussiefrog cars - I fitted my kit to the R10 tonight (1.4L with Ducellier ignition).
I ended up purchasing the Pertronix "Ignitor" kit with matching hi-performance Coil. Had to be shipped in from the states, but obtained with no dramas other than the wait for shipping. I have to say Pro-Quip in Melbourne were most helpful in sourcing the kit and expediting it up to me. I've had it since end October, but only just now got around to fitting it.
The kit was easy to install - much easier than expected. Required a slight modification to one of the existing points plates (which gets left in as a backstop to prevent the Module from moving as far as I can tell). I just need to put a dab of silicon on the wires exiting the distributor body (I used an exisitng grommet rather than the one supplied as the penetration was too large for the kit's grommet); just to make sure the external section of the wire doesn't get bumped and push it back into the coil and into the way of the rotor button and the job will be fully finished.
I took my time and was extra slow and careful and it took me less than 45 minutes from go to whoa (or whoa to go as the case may be).
Road tested the car and it is definitely running better and feels slightly more responsive although that may be due to fixing other issues during the course of the install.
Overall; definitely worth doing in my opinion; although as someone said in the threads previously, the cost adds up to a lot of sets of points. The total cost was 284.90 for the ignitor, and 120 for the coil giving $404.90.
Will give an update after the car has been tuned and done some more miles as opposed to just around the block.
