Does anyone have a cut away pic of the fuel tank that they could post. The cut away image would help me understand where the baffle walls are so I can try to use wire (or similar) instrument to scrape away the gunk off and also determine what size stone to use to agitate the gunk.
I suspected that the tank is full of gunk and rust, the engine cut out when the fuel level would drop below 1/2, previous it was about 2/5 full but initially it was about 1/3 full when I inspected it before purchase the engine would have trouble starting until fresh fuel was put into the tank.
I have confirmed my suspicion, its really bad. I initially replaced the fuel filter (date stamp on filter was just over 12months old) with a cheap plastic clear filter which within 2 minutes of the engine idling was full of gunk and rust.
I have removed the tank from the car and have emptied the remaining fuel, it came out like dark coffee. Sticking my finger in via the drain plug hole there is about 10mm of gunk (if not more) settled on the bottom of the tank.
Some pics to the reality of the tank gunk.
