Interesting solution you came up with Steve. Worth remembering in case we are caught out somewhere without access to a wreck to raid for a replacement. I guess owning a DS has led to many engineering innovations around the world, especially in more remote areas as people have fought to keep the D going.
Ken
Ken
Hi Ken.
Had the exact same thing happen many, many moons ago with my brake fluid 68 ID19B in 1972. Had lost a front sphere (keep in mind that in the US we did not get LHM cars until 1/69), replaced it and soon there after the car started riding a bit harder and harder. And in turn the front height keep getting a bit more each time the car was started up - as well as the car not loosing front suspension pressure, even overnight. Deducing - after taking the HC apart and cleaning that did not solve the problem, that the problem was crud from the blown sphere clogging up the return line from the HC (and boy what a mess was created when I cracked open that line). I replaced it with a line that I had made up from some steel tubing and a line tool (from Terry Keeton) that applied the 'Citroen' bump to the line end. Put on the car and problem solved.
It also made me realize that there was a some type flow restricting in that line as, now, the front of the car would drop like a falling brick when put in the low height setting . Salvaged a line from a car being wrecked (sever front end damage due to an accident) and all was back to normal - at least normal for a Cit . To sort of duplicate the factory line I plugged brazed the end of the replacement line I had originally made and drilled a 2.0 mm hole (same size as the by-pass holes in the replaceable shocks) in the brass plug. Worked darn close to the factory line. Looking back on it I should have made the hole a bit smaller, but it worked OK and just left it.
Steve
