Hi Guys
I have had an ongoing problem with the rear end of my car sinking quickly, also accompanied by a very frequent tick rate from the hydraulic pressure regulator. I found that the brake valve is returning fluid to the reservoir like it's going out of fashion. I hear this a common fault, rectified with a replacement brake controld valve, aka doseur. Is the ebay item in the following link one such part? The item description calls it something else.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=4565543389&fromMakeTrack=true
I heard they can be repaired with new seals but it would yield a more permanent fix if the whole part was replaced.
Andrew.
Andrew.
