Don't think it would be to hard to work out:
Red to battery positive
Black to battery negative
Green to negative terminal of coil
Then turn the knob to the required setting and read off the appropriate scale
This is a shunt for the current. Remove the wire that feeds what ever you are testing, put the fork end where the wire came from and then place the wire under the black screw.Thanks Col, I was thinking more of all its capabilities; it did come with instructions. How's this used? It is in addition to the red, black and green.View attachment 215510
John
Thanks Col, may I say you've got one? Do you still use it?This is a shunt for the current. Remove the wire that feeds what ever you are testing, put the fork end where the wire came from and then place the wire under the black screw.
Thanks Seasink, yes back to mechanical distributors, they were good enough to go from London to Sydney but have to agree a thing of the past - the motor car has come a long way as we found out with the purchase of the latests Peugeot 508 GTBack to mechanical distributors!
Dwell.
It's for points gapping, with 12v feed.
Connect the red lead to the ignition coil low tension, and the black (or green) to the disconnected low feed to the distributor. Turn over the engine. The meter reads the angle of rotation for which the points are closed. The car handbook will give the desired angle. The meter is in series with the points
To reduce dwell increase the gap, or vice versa.
I had a similar tool many years ago, but the meter movement got dislodged and was then useless so I binned it.Thanks Col, may I say you've got one? Do you still use it?
With the advent of company cars, there's been no need to use a few of my collection of tools and gadgets but now, playing around with cars that I drooled about 50 years back; it may be time to dust them off.
John
John
