Hello my friends!
Well, my never ending story about the large oil leak in my CX22TRS is here again :wink2:
In order to be 100% sure that head gasket was the culprit, I did again a test, cleaning oil in the suspect zone and running the car to work. Back at home I was happy to see that oil seems to come from a location higher than head gasket
In the picture, you can see distributor and HP pump belt pulley, located at the upper right side of engine block. Oil seems to come from the gasket between the engine head and the metal casing which supports distributor and pulley (hope you understand my poor explanation!)
But, of course, it only leaks from lower part, hidden by pulley and belt and going directly to gasket head zone, which is what puzzled me
Now comes the question... is it easy to fix this?. I would need to remove HP belt pulley, distributor and metal casing. BTW, which is the correct way to remove pulley bolt, without risking to damage the cambelt ?
Thanks for your help!
JOSE
JOSE
