I have a cruise control here which was functioning before removal from a Son's car. It's a Command AP60 unit.
Having installed it in GiSelle the GS I'm reaching breaking point with the %#$%#^$&^%# thing! If anyone out there in Froggy Land is familiar with this unit, could you please peruse the following and see if I've strayed from the path somewhere?
Firstly, the base unit is supplied with switched volts and a good earth. (Both checked, several times).
The control unit has 4 wires going to it from the base unit. These all seem to function correctly in that the LED on the base unit reacts according to the installation instructions. It switches on when set, res and brake inputs are energised, and comes on for 8 seconds when ignition is turned on and thereafter toggles with the power switch. The control unit LED is very dim when on, but has occasionally lit to full brightness, for no apparent or logical reason. The LED is operated by a transistor on the PCB switched by a 4013 dual logic IC. Putting a hard earth on the relevant wire at the base unit connector results in the LED lighting normally, so the wiring connection is fine, I assume.
With the exception of the LED on the control unit, the diagnostic tests all give a positive result. Accessing the diagnostic mode results in audible clicking of both set and vent solenoids.
The LED on the base unit cycles with rotation of the monitored wheel.
The brake light switch has constant 12v on one side and the brake lights on the other. I've tried reversing these and no joy.
Oh, and there's a good vacuum supply to the servo unit, and I've checked the solenoids and wiring of this.
Despite all this, the unit resolutely refuses to take up the slack and function as a cruise control.
I assume there's a faulty input somewhere, and logically it may be related to the aberrant LED behavior on the control unit, but so far I'm stonkered.
Anyone with ideas, I'm happy to hear them.
Cheers, Pottsy.
Cheers, Pottsy.
