So it's not a three potter.Mine is the one and only 1.6 ep ever on a 208 a most different one from all the 1.2
Is the EP engine really that hard on plugs?More like 40,000 km. They last longer, but not forever.
You need a strong candle when you blow hardIs the EP engine really that hard on plugs?
Someone told me the iridium plugs are for life yet this one needs changing
In my V6 Laguna, which has similar engine I get 120,000 Km from a set of plugsWell anything can fail... I understood that iridium or Platinum plugs were good for about 100,000km - perhaps that is life for modern cars? The mighty ES9J4S is onto it's 4th set (or would be if the Iridiums had been used from new).
View attachment 220687That weeny little 1.6litre motor is generating this sort of power and torque. I'd certainly be keeping ontop of the service items like sparkplugs for sure.
To put it into perspective, the 4 litre v8 in the shitbox here ... when new (so more the twice the engine capacity and twice the number of cylinders .... and probably 10 times the fuel consumption) is 180hp (not 266hp) .... and 312Nm (not 330 over a huge rev range).
it really is phenomenal the performance they are managing to get out of a 1.6litre motor.
Peugeot sport engines need plugs every 20k from memoryView attachment 220687That weeny little 1.6litre motor is generating this sort of power and torque. I'd certainly be keeping ontop of the service items like sparkplugs for sure.
it really is phenominal the performance they are managing to get out of a 1.6litre motor
My weeny little V6 (ES9J4S - 2.9 litre) was rated when new at 204 bhp (152kw) at 6,000 rpm and 285 Nm at 3750 rpm. Both our engines are of course naturally aspirated - not fair to directly compare them to a forced aspiration engine. I've certainly hit peak torque often enough (rarely in top gear, as that would be c. 150km/h), but suspect I've never hit peak power - in any gear!
The ES9 V6 weighs 195 kg. According to one spec sheet I just looked up, it has a life expectancy of 350,000km, so I expect mine will fall out on the road any day now. Perhaps I should just put in the recycling bin...
No doubt ... someday. The modern cars just don't really interest me to any extent. Can I fit the motor into a Traction Avant maybe ?Treat yourself to a DS3 THP ride, DC. 6 speed manual. All that torque not much over idle.
And laugh at the dills who pull alongside at lights and intersections to get away from the little "shopping trolley" whose name they don't recognise. They never notice that the rubber band tyres might signify something.
the 1.6 is 199kw ....I love turbo engines, my Megane GT220 1995 cc 161 Kw & 340 Nm no turbo lag
I can spend a grand and turn the wick up to 223 Kw. The GT220 is detunedthe 1.6 is 199kw ....
