for those who are running 604's i have just finished modifying a 2 litre escort air cleaner to fit onto a weber on the other 1/2's 604
they are plastic in construction and i cut the snorkel back to around 40mm from the air cleaner and fitted a 75mm dia tube from there all the way down to the front of the engine bay with a 200mm bell on the end so as to force cool air up into the air cleaner
the difference in economy is simply amazing and the car seems to have a little more pick up on the open road as well
all i have to do now is adjust jet sizes a little for a little more economy
the car doesn't need to be an ultra quick car for her but i don't want to sacrafice all the power
mind you the car just returned from melbourne towing another 604 from there fairly easily and returned around 16mpg average and that was without the cold air pipe and new air cleaner
maybe i should have made this mod before the trip
still on the hunt for a low comp inlet manifold for a 604 and a pair of late model 504 lower control arms so i can lower the front end by around 3" and retain the camber angle
