....i changed the plugs on the s16 today, replaced them with some NGKs,...Naturally to change the plugs i had to remove the Cover (cast aluminium/steel i assume)..anyway once the cover was removed (which i assume was designed to keep the coils as HOT as POSSIBLE...duhh...)...the coil-on-plug was revealed....WHAT a pile of CRAP...i really am not impressed with this...I thought coils WERE supposed to be kept away from heat???? I realise the DISTANCE from COIL2PLUG should be kept to a minimum but this is redicilous if its going to affect reliability in the long run....SURELY there must be an alternative...I would preffer to see the coil packs mounted externally (of head)...what are the options here??
ultimately I d like to run the 16 valve on either a DUAL coil or a single unit?options please?Any resident ELECS on the forum?....advice and opinions please???
cheers
dino
cheers
dino
