Hi Greg, is the Windsor unit the modified under-dash set up? (Autoclim factory?)
Adrian
Adrian
but the air-con man suggested the seals may seal themselves, since it has not been driven for 5 years till now
and the new air-con man was not very enthusiastic about Hi-Chil. He says it does not have the same heat absorption capacity as 134a.
Based on experience he wrong is on both counts.
Possibly time to find a third air con man?
It seems to me that the passenger compartment is quite well sealed. Good door and boot seals!
A fan forcing air into this compartment will eventually be forced to cavitate as the air pressure will rise slightly above the out side air pressure. Bit like trying to blow more air into a fully inflated balloon.
The C pillars on my CX have this nice brushed aluminium trim complete with horizontal air vents at the lower edge.
I found that when the trims were removed that these vents had been rendered useless. The factory had stuck a piece of vinyl over the corresponding outlet in the C pillar underneath the trim.
The air in a non air conditioned car is supposed to flow through the cabin and exit through these vents. There is a section on the inside C pillar trim that is shaped to allow air to enter and then pass through the C pillar from the upper inner duct down the inside of the C pillar and out to the external atmosphere.
Of course I removed the vinyl patch and consigned it to the bin.
It is amazing how much more air now passes through the cabin from the fans.
I have yet to refill the air con system with Hychil. I do however look forward to an efficient cooling from the system. The car's aircon actually was not bad when I had it on the road fourteen years ago. It was only filled with an R12 substitute ( not sure which one ).
The key to having it work well was to allow the warmed air out as the cooled air was fed in. This is probably why the cars that still have that silly patch in place only function well on 'Recirculate'. The air has some where to go in the recirculate mode!!!!!!
By the way this car is a 1978 model with the early single evaporator in the console.
Another important mod was to install a secondary vacuum operated heater tap to back up the original manual tap on the side of the heater box. That tap also had to be reconditioned to work effectively!
A $2.50 12 volt hobby motor equals a working vent motor. Hack saw off the imbedded motor. Remove gear off burn out shaft. Refit & test. View attachment 52447View attachment 52448View attachment 52449
Is the motor you fitted designed to sit stalled indefinitely the crazy design of that motor means it'll drive to the end of the flaps travel then sit there stalled permanently until you change the flap, then it'll drive to the other end of the gear and sit permanently stalled there Crazy design !
