Hi, on the subject of this mirror, is it easy to pry of the indicator light to replace the bulb ?
How easy would it be to access the wiring of that indicator? (without removal of the mirror) tx
I may be wrong but I believe you replace the indicator unit as a whole, I don't think you can just replace a bulb - could be wrong
https://www.micksgarage.com/d/wing-...ght-mirror-indicator-for-citroen-c5-2008-2017
Yes, you can remove the unit without removing the mirror. Around the centre there are two spring clips, carefully prise from the underside (least likely to show accidental damage) and the unit can be released. There is a multi plug that is incorporated into the loom so not great access other than to plug/unplug.
