Check DPF DASH WARNING
tasie C5
St Helens Tasie
Son's 2011 Peugeot 4007 diesel manual has a "check dpf" warning come up.
Could it be Eolys low or something else. In recent weeks he has several 3+ hours runs so I assume a re gen burn would have taken place.
Any suggestions for a mechanic in Bunbury WA.
Mine been doing this every time I drive it with fuel on for 100kms. So now fill up earlier. Got sick of clearing the codes.
You need to get the codes read, it may be eolys low, it could even be the fuel cap. If it doesn't know the caps been refitted it won't inject eolys, then won't do a burn.
Scanning it and reading the codes is what's required
Thanks cav9. The car has done 180k. I wasn't sure if it had an eolys system. The car was purchased in Perth and was well maintained.
Not heard of the fuel cap issue.
Chances are the DPF could be on its last legs and be blocked even thou/gh everything is working properly. Thats what our problem was a couple of years ago when throwing errors constantly, had done similar KLM also
