Carby cleaners
nJm
Guru
Melbourne, Australia
While I was browsing through my local CarBitz shop I saw aerosole cans of carburettor cleaner. I was wondering if these products really work, and would it be worth while putting some in my car?
Some things look a bit gimmicky, so I thought I'd check here first blush
be carefull some of the cleaners can make more problems than you are trying to fix.they can wash dirt into other ares of the carby that can cause worse running faults.they are ok for cleaning bits once they are removed .generally if a carby is that bad it should be pulled apart most likely.some can atack the carby alloys and strip layers off the inside blocking jets and needle/seats.
