Southern bearings in Abotsford are pretty good on old Renault bearingsThanks for this everyone who replied. Most helpful. Have passed it all on to the mechanic. Let's see what happens.
With any luck you are after 30203 and 30204. The last ones I bought were readily available from a standard bearing supplier in Perth (maybe 4 years ago, as spares for a long trip) and they cost around $10-20 each. If for some reason you need the later type of inner bearing, it is an overseas purchase. I do know of one mechanic who machines up a spacer for the inner bearing so he can use a standard one. The factory bearing has an integrated inner spacer. With a 1964 car, you never know what earlier owners have done - it might even have later stub axles!Thanks for this everyone who replied. Most helpful. Have passed it all on to the mechanic. Let's see what happens.
I'm not quite sure why it isn't done more often! Maybe it is...With a lathe the integrated spacer could be cut from the old bearing and then a standard bearing would fit.
Machining hardened steel in a lathe is extremely difficultI'm not quite sure why it isn't done more often! Maybe it is...
Walked in to Southern Bearings and told them: I’ve just bought a ridiculous car. The response: Is it an old Renault?Southern bearings in Abotsford are pretty good on old Renault bearings
Don't overtighten them. It isn't a modern FWD device.Walked in to Southern Bearings and told them: I’ve just bought a ridiculous car. The response: Is it an old Renault?
Aahh..
I now have the bearings as suggested by this forum. Fingers crossed they’re the correct ones.
