I went over a bomb crater (a bad bad pot hole)
, lost the hub cap (got crushed...) and the rim has a slight flat spot, so it is out of round, if you know what I mean. cry
My question is:
1. How easy is the wheel alignment likely to be affected?
2. Can the rim be re-balanced and continue to be used?
It's a steel rim, so getting a new rim is probably cheaper then getting it rounded. Also I can always use the spare rim, and use the damaged rim as the spare, but is it going to be good enough for long distance travel if I had to use it?
Thanks for your help.
My question is:
