I think they only brought about two petrol C6s into Oz, so diesel it almost certainly has to be...
Don't you just not need the spoiler when doing over 140kph
Definitely a 2.7HDi as the VIN contains UHZ. The ES9 probably has fewer vices in old age compared to the diesels, but there are a few lower cost workarounds and some engine items can be found from Ford, Jag and LR. Some faults you just have no option other than to pay up $$$$ to fix if you want it working correctly, remembering the oldest C6 is now a 14yo and youngest pushing 10.
Freight on inexpensive but bulky used parts from Europe will be the killer.
Don't know C6s much, but also should the "service" be lit on the dash when ignition "ON" unless a problem?
I would taking a close look at this vehicle personally. Check out the 3rd image it appears to have a "pumped" rear drivers side rear quarter.
I would suggest there could be more damage than what superficially is showing. It also has missing front lenses from the front bar(Indicators?)
Headlights need polishing if recoverable which also indicates to me it has had a large part of its life not garaged.
No books or service history makes one ask. Why wasn't it repaired? Does it have repairable title?
My two bobs worth
Cheers Andrew
