Was reading the last comment about the front being very low, but you are probably correct Armidillo that both ends are not rising. Odd, if the pump runs OK and has plenty of LDS, it may be an internal fault and the level adjustment operations may have been disabled.
Any fault codes known?
In addition to that 40A fusible link, which is also in the 2.7HDi, there is a control relay that can fail. If the pump motor runs normally, those should be OK. Loss of prime might explain it.
