seasink would the complete arm encompass all the bushes or would eai be able to supply a full kit do you think .That's them. But it is much easier to buy a complete arm with the bushes fitted.
David do you think EAI would be able to put a complete kit together for the front end if I provide them with the vin then it should be right for another 150k#8 does wear out eventually, but the two most common failures are the round bush in the bottom of the upright (near #32) and the bush at the back of the control arm, which doesn't have a number on that diagram. You need to know if it has a steel or aluminium subframe because he bush at the back of the control arm is different. Try EAI as Citroen does not sell these separately and expects you to buy new control arms and front uprights.
