Hi crosspug -
You should be able to follow the 2 rubber hoses attached to
(LHS wheel arch) front strut rubber leak-off hoses - all the way over the subframe - ending up with the 2 plastic tubes in question.
The correct routing for these pipes is inside a large plastic sheath residing on front of the subframe. The plastic sheath is there for physical protection & fixing of the pipes only.
These 2 plastic tubes in turn is a push-fit into the rubber (Octopus) dingy that resides in the most silly place over the engine lower mounting. The pipes simply pushes into the rubber from left - and will lock in the rubber by the indents on the ends.
It will be MUCH more clear if you do an engine clean in the area.
Because of earlier epairs or re-locations - these pipes may now simply be too short. No problem. Extend with anything handy - like suitable diameter fuel hosing. Just have to cope with mineral oil based LHM under leak-off (seeping) "pressure".
Good luck.
You are in the best hands on this forum
Good luck.
