- Joined
- Aug 2, 2000
- Messages
- 11,484
Any ideas as to whether a BX hydraulic pump will fit a Xantia?
Graham
Graham
Both the BXs I have pulled apart have had the pump near the alternator. These were TRi and TZi. What sort of drive system would be used from the gear box end??Dave B said:The BX pump drives off the gearbox end of the cam whereas the Xant pump is mounted in the altenator area, so no. Also the Xant pump has 2 outlets, the BX has one and a different pulley.
ajpolden said:Which model Xantia?
The I know the VSX hydractive ones have a multi-cylinder pump - something like 6 cylinders to drive the powered steering and only 2 for the rest, in which case a standard BX pump would not suit. Perhaps someone else can add to this?
Regards, Andrew.
GRAHAM WALLIS said:Both the BXs I have pulled apart have had the pump near the alternator. These were TRi and TZi. What sort of drive system would be used from the gear box end??
Graham
Alan S said:I can only refer to CX systems, but the old pumps on those were driven like a fuel pump using a an arm on a cam lobe and the pump bolted to the block.
If you can access a specs of both via service manuals, that might be your best guide.
My Xantia has a pump fitted that is poles apart from the BX pump right down to the location and mounts used. In this instance, 'twould be a braver soul than I who tried to fit one to the other. :nownow:
Alan S
Graham
