Background
* The 205 has pulled left since I got the car. The heaver the pedal force, the more it went left.
* Sometimes, there was a 'loud' clicking noise as the brake pedal was depressed. Not when released.
* There is slightly less pad left on the LEFT caliper then the right (indicating that the right caliper was not engaging properly?)
* I've had the right front wheel bearing replaced as there was some sort of bearing noise coming from there.
* With the car in the air, the right wheel wouldn't turn by hand.. caliper locked on?, left turned freely
Work Completed on the Car So Far
* Removed right front Caliper from the hub disconnecting all cables etc...
* On a bench I blew the piston out with compressed air, cleaned, and replaced seal and dust boots etc.. I also lightly sanded the surfaces with 1000 weight paper.
* Installed piston back in. Slid very well back into the housing.
* Cleaned and re-greased guide pins (FYI the mounting bolts go thru the guide pins onto the hub assembley)
* Installed caliper back onto the hub. Mounting bolts tightened to recommended torque setting.
* Bled 500mL through the front system (the rear has a separate fluid holder, so didn't do that)
* Greased (lanolin oil) the pivot point on the brake pedal
Problem
* The car still pulls left (sometimes). It depends on the 'clicking noise' I.e. the car will pull left, then I'll hear a click and * the car will go straight, press a little harder and it goes left until the clicking noise.
* When depressing the pedal, there is loud clicking noise from the right front caliper still occurs. The clicking noise continues as the pedal is released (i.e. I think the piston is now sliding properly )
* I've bled the fronts without air coming out, however the pedal still feels crap.
* If I depress the pedal hard towards the floor and release, the pedal returns back very very slowly to the top. the car doesn't move on a hill until the pedal is all the way up.
* Sometimes, the right front locks up very easily...
If you have any idea what I can do, look at, replace.. ANYTHING!!! I would apreciate the advice.
Justin cry
peugeot_
Problem
Justin cry
peugeot_
