We often hear about the UK spec BX 16 Valve/Mi16 motor having more zap in European form than the Aussie one.
One guy from over there who is a registered member of this board & who has asked questions regarding Cat removal in the past has just posted that he has at last (after about 12 months) found out the difference & what is required to convert to UK specs or in the case of a BX to Mark 1 specs.
Maybe I'm getting a complex but; this is what HE said, NOT ME!! I recently posted a message from another board along with the same type of disclaimer & finished up with everybody basically calling me a tosser based on the other guys comments - maybe they're right - just didn't know how to tell me before
Hi folks
Useless info time again! I've been trying to find out what the differences are between my cat-equipped 16V and a non-cat version - and at last I have what I hope will be the definitive answer!!
I got my local main dealer to look into the differences in engine part numbers between 2 chassis numbers - 1 cat 1 non-cat.
I was led to believe that cams and/or pistons could be different and therefore trying to get the full 160BHP out of my engine wasn't possible.
It turns out that the main difference is down to the use of unleaded petrol. The valves are slightly smaller in diameter due to larger valve seats designed to cope with the higher temperatures generated in an unleaded and cat-equipped engine. The ONLY other difference is a different head gasket designed to cope with higher temperatures also.
I therefore can guess why my head gasket is beginning to weap to the outside world (apparently as I haven't seen any evidence myself) since the gasket was changed 3 years ago when the head was rebuilt after the belt snapped. Seems likely that the standard gasket was used by mistake assuming they checked the head was flat before putting it back together!
The good news is therefore that if I'm prepared to fork out for a head job and new valves I can easily get the 'lost' power back and if I opt for cams also a bit more besides. Guess that stainless exhaust will be right near the top of my shopping list after I get married in July!!
I'm now a bit happier about the potential for more power out of the old girl - anybody got a ported head for sale?!
Adrian
Hi folks
Adrian
