My smart charger has a 12v power supply option. I just use that setting for 10 minutes or so, then switch to the appropriate setting (wet, calcium etc.). No need for an old charger or jumper leads and a good battery...i think we have been through this elswhere ,but i have discovered that if your modern charger dousnt recognise a dead flat battery ,connect another charged good battery to the flat battery with jumper leads ,for a while ,sufficient charge will be transfered after a little while, so the two batteries can be disconected ,the charger connected to the flat battery then the charger , is able to run tests and charge the once flat battery aproprietly
Kickass make battery chargers which I think are nearly as good as CTek without the high price tag.The best intelligent charges are ctek a little pricier than some but they will even "restore" a battery if it's not to far gone.
Hi.Kickass make battery chargers which I think are nearly as good as CTek without the high price tag.
12V Battery Chargers
Looking for 12V Battery Chargers? Make it KickAss! Shop a range of KickAss 12V Battery Chargers Online or in-store. Australian Owned & Operated. Fast Delivery Australia Wide.www.kickassproducts.com.au
