The gearboxes haven't changed so it still appliesI'm pretty sure I remember it being said (Bruce Taylor?) that it must be multigrade, non friction modified oil. Not sure if this still applies.
The way that these gearboxes are filled, as you may know, makes it very difficult to overfill them. The selector shafts are notorious for leaking...only small leaks, but they add up and need to be checked more often than people often bother with.I think people overfill the gearbox and the excess leaks out.
How does one check the oil level?The way that these gearboxes are filled, as you may know, makes it very difficult to overfill them. The selector shafts are notorious for leaking...only small leaks, but they add up and need to be checked more often than people often bother with.
I have done the 'jack the right side up a little' trick, probably only amounted to about 100ml over the level. No problems at all...to create a serious overfill issue would be difficult to do on them, imo....but from what I have seen (the 5 speed only), they can easily suffer damage if only down on the level by a small amount, so I'd much rather have it slightly high than slightly low.How does one check the oil level?
For years I used to fill to the bottom of the filling plug hole.
The last time I re-filled the 504 box I put 1.15L in (That's what the book says). The level did not come up to the bottom of the filling plug hole.
I only had the box apart once, but seem to remember that inside where the vertical selector shaft comes through the area around where the shaft protrudes is raised. Maybe the filling level is just below this surface.
I must admit that mine has leaked for nearly 50 years, not so much lately though.
The only check I do is if the selector shaft bottom lever has no oil drips on it THEN there is probably no oil in the box!I have done the 'jack the right side up a little' trick, probably only amounted to about 100ml over the level. No problems at all...to create a serious overfill issue would be difficult to do on them, imo....but from what I have seen (the 5 speed only), they can easily suffer damage if only down on the level by a small amount, so I'd much rather have it slightly high than slightly low.
As for leaks ...yes the selector shafts are known for it, and that's not from being overfilled; on the 5 speed the gate selector shaft doesn't appear to be able to be serviced, which to me is a bit ridiculous. Anyway, they need to be checked more often than a lot of people seem to realise.
