My car is a Peugeot 505 GTI (1988).
Just recently gear changes have occasionally been a touch clunky. I was advised to change the transmission fluid by draining the sump, topping it up with new fluid, driving for at least a hundred kilometres and then repeating the exercise 2-3 times until the fluid was once again bright red.
The first time just under 2 L drained out, the second about 1.6 L whereas I'd been advised to expect that 3 L + would drain out each time. In any case, even after the first time the gearshifts did seem to be a little smoother.
Having completed the second change today I went for a little drive to see how it felt. Everything seemed good but it suddenly dropped out of gear less than 1 km from home. I can move the gear selector (and the arm on the side of the transmission still moves accordingly) but none of the positions engage any of the gears. In reverse, there's a bit of a hum as if it's trying to do something but no engagement and in all of the other positions, nothing.
We towed it back home and I checked the fluid level which had dropped to the end of the dipstick. I topped it up (took about half a litre to bring it back up) but that didn't make any difference so I just left it.
Many years ago I put two separate problems to this esteemed forum and got terrific feedback so before making any other moves I figured I might get lucky for a third time.
Ingolf
Ingolf
