Auto electrician central West NSW
dayofthejackal
Active member
Any recommendations for the Harden / Young /Yass area . Looking for someone interested in 1980s L-jetronic issues
Can't make any suggestions, but a little self-help and own diag can help a lot. Does the fuel pump run? If not, it is usually the tachometric relay at fault. It's a larger relay that is often blue or black and has more connectors than your typical relay. It takes an ignition pulse and turns on the fuel pump. You can pop the cover and manually close the contacts to see if the pump will run. If the car has sat for a long time, be very careful of the fuel hoses and stale fuel.
