Well I decided seeing all the hosing rubber indicates early 1990's it was time to change out.
There have been a number of issues with things not done properly on this car so rather than just replace all hosing as it was.
1. Oil from engine where full flow oil filter is normally mounted is plated off with centre hole securing this plate to the crankcase & another hole is in the periphery of this plate. Hoses go from both these locations.
2. There is a remotely mounted oil filter
3. also there an oil cooler
There were 3 Ryco barbed hoses removed for replacement, so before I start cutting to length & securing fittings could someone help with a schematic of where these 3 hose should interconnect with some basic explanation please.
Many thanks,
John
Many thanks,
John
