G'Day All,
having put some effort in recently to a bit of a 'Refresh' of the 505 it was a bit disappointing to have a near breakdown on Weds night. We'd done the airport run to Sydney earlier in the day to collect son & daughter-in-law in the "Limo." On the way back weird things started to happen with the electrics, first the wipers packed up (intermittent rain was happening ), coincident with this the battery warning light came on (nice & bright after my dash bulb replacements), then the indicators stopped working (I know I made the dash illumination BMW red but that's ridiculous ). At least the main lights were still going so we made it back with frequent stops to wipe the screen. First thought was alternator's packed up but there had to be something else too. I noticed that every time I braked (engaging the brake light circuit) the temperature gauge plunged to zero (fuel gauge also seemed affected), and the battery warning light got yet brighter. The dash clock also seemed to be desperate to join the party alternately being off and on.
With my limited expertise in electrics symptoms looked typical of an "earthing fault" to me so yesterday first tested the battery which reported "health 100%, charge 97%" - think alternator's OK. Then I took off the panel under the steering col, took off the stalk switches & tested with a multimeter (they were both operational). There was an 'earth' connection to the bracket under the wiper switch which was very obviously not an 'original' fitment. back up the line from this it was grafted three ways, one a very thin wire (looked like speaker cable), one thicker red wire, the third into the 'original' wiring harness (black cable). Other side of the bulkhead (near the fusebox) there's a 'multisocket' not connected to anything with the same bundle of colours as the harness under dash, indeed there's continuity between 'earth' terminal & black terminal on multisocket. In all the faffing we must of reconnected the battery a bit 'early' (bad practice ) 'cos when I was refitting the 'earth' I got a spark! With the multimeter there was 11.9 volts between the rogue 'earth' terminal and 'real' earth. Decided to replace everything except the mystery 'earth' after which wipers worked again, indicators ditto, battery warning not lit with engine running. Biggest surprise of the lot (given the thin wire / red wire disappeared behind the central console at about the 'latitude' of the radio) was the radio appeared to still work. Think I'm out of cunning plans now other than to drive around for a while to see what (if anything) doesn't work.
One other piece of 'trivia' when the 505's between gigs I'm fastidious about disconnecting battery - without doing so between a month & two its too flat to start the car. Now same applies to both the ZR & the Smart BUT these last two are shot full of computers, immobilisers, alarms, & God knows what other power-sapping shite so only a surprise in case of 505 which should only be powering dash clock 'at rest.'
Does anyone have any further insights??
Thanks, Rob
Thanks, Rob
