I'd be looking for a replacement that requires less work instead, ade. You can spend a fair bit of money on a bad head and still find it gives up the ghost at the first sign of stress. Should be someone on the board with something to offer.
If you want to get it checked out then Dave at French Connection would probably be able to give you some good advice. <a href="http://www.french-connection.com.au/main.htm" target="_blank">http://www.french-connection.com.au/main.htm</a>
Rod
<small>[ 21 July 2003, 09:48 AM: Message edited by: Rod Hagen ]</small>
