I have a spare one, will try tomorrow. Fingers crossedThe coil is easy to replace....just to be sure it's not that .
Hi.The only thing that seems to help is if I pull the choke a bit more than halfway, the engine will idle the way it is supposed to, and does not stall! I guess the issue would be fuel starvation? It's a new fuel pump, and idles fine when on a flat, floats are good, I have tried mucking around with the mixture screw, with not much success. The revs barely change when I screw the mixture screw in or out. In fact, I've had it screwed all the way in, and the motor still ran the same as it was 5 rotations before. Any suggestions people?
Hi.Okay, went out and got a Bosch Alternator, photo attached. She idles better and is def smoother, but alas, still stalls downhill with lights on. With lights off, does not idle as well when stopped on a slope (bonnet facing downhill) but keeps ticking. This makes me think it is not a fuel line issue. I have found that if I pull the choke on a steep downwards gradient, it stops it from stalling. Uphill, no issue.
Just did, some damage to main float. Primary Float arm bent downNo expert on 504's, but what about float level?
Look in the workshop manual for your car, it will also tell you what the correct level is for the floats.Hi Whippet, thanks for all that info! I have just done the basics but will look into other suggestions. I recently replaced the coil, not the alternator, as to rule out any weak spark issue. It was idling rough on a level surface, but would stall on a steep gradient. Once I replaced the coil , it smoothed the idling out. Volatge is 13.2 with lights off.
I have just pulled the floats out for a second time and noticed the housing for the primary float is bent (see photos). Secondary float is straight in comparison. Will try bend this back into place and see how I go. Currently not pressing against ball bearing as required. Maybe this is causing fuel starvation on steep slope. Also, how do I go about adjusting float levels?
Hi James Gelido.Look in the workshop manual for your car, it will also tell you what the correct level is for the floats.
Hi.I recently replaced the coil, not the alternator, as to rule out any weak spark issue. It was idling rough on a level surface, but would stall on a steep gradient. Once I replaced the coil , it smoothed the idling out. Volatge is 13.2 with lights off.
Thanks for your suggestions mate! I appreciate them. Separate carbies, yep. Adjusted both rods/arms to manual specs, not much change I'm afraid. No orifice in primary carbie, only secondary, which is how I received it. Nothing seems top have dropped off either. I assume that is how it comes?Hi James Gelido.
For sure use your workshop manual as your reference and guide, as Col has mentioned.
You mention Primary and Secondary. I suspect that these are separate carburetters? If so, they would work in unison. Primary and secondary barrels are usually contained within a single carburettor.
1. I would assume that both the brass rods that are the hinge for the floats, should be parallel with the gasket surface of the housing. From the images it seems that one is low and the other is high.
2. From the image, there appears to be the brass tube with orifice missing from one of the housings? Where is it? Has it fallen out and is sitting in the chamber that it inserts into?
Cheers.
