Around 25 years ago I had my Ti completely overhauled, new every bloody thing ($$$$$$'s). Injection pump overhaul and all.I wonder if this is actually a fuel problem?
I dont think the disy from the GL will fit in the TI because of the air intake tubes but the TI one should fit in the GL as a test. You will have to check the timing again .Also as was said before you could try an extra wire from dissy to coilI have tested my meter (tachometer) on another 504. It works perfectly, so the fault is with the car not the meter.
Connected the induction clip of the tachometer to the main HT lead between the coil and the distributor cap. The fault is noticeable there too.
I have fitted another coil, but the fault remains.
I’m thinking to fit the proven distributor from my GL into the TI as a test. Can anyone tell me if they are interchangeable? I imagine the advance weights and/or springs are different, but just for the purpose of the test, running the engine at idle, will it work?
