I need help navigating the plumbing on the 504 engine in my 404 ute project
Photo no 1- under the carb. (the carb is the twin throat progressive)
The big ugly one is obviously water. I'm guessing the one beneath it is for vacuum for a brake booster? Above those two, the small one sticking out is the vacuum advance for the distributor but there are twin larger vacuum (I'm guessing they are!) outlets pointing to the front & rear of the carb. Are they for some other auxiliary function? Automatic transmission?- so I just have to put a loop in to seal them?
Photo no. 2- base of the inlet manifold, flywheel side. One water connection. Where to?
Photo no.3 Water pump. 2 outlets, one larger. Where to?
Photo no.4 Rear of cylinder head. Two outlets. One larger. Where to?
