If you are going to use one of the double mini fuse adaptors there will be a fuse that has power switched. I don't have a 407 but the BSM (engine bay fuse box) you can check with a multimeter. Or run wiring to BSI (under dash fuse box)
Not many other options without building your own circuit off the battery
