Well, here we go again! The clutch renewal went well, the speedo needle doesn't now sometimes drop to zero and the rear main crank seal doesn't drip oil.
However, although the drivers side drive shaft is snuggly fitted up against the diff housing, the same can't be said for the passenger (left hand) side. It is about 6 - 7 mm out and I can see the shiny surface of the shaft, which I don't think I should be able to see. The gearbox is not losing oil.
I've tried giving it a good push, to no avail. Am I not using enough force? Is there something I don't know? This wouldn't surprise as there are tons and tons of things I don't know.
