Hello all,
I've searched high and low here and elsewhere on the internet and can't really find a issue similar to mine.
My 1997 406 ST (2.0L, 80,000km) with the manual ventilation controls developed an issue a couple of months ago where the interior fan stopped working properly. I could move the fan speed slider up and down and it would only work on high speed. The D8 has the resistor module bolted on to the fan assembly and is quick and easy to change, so I picked up a new module off eBay and installed it which fixed the problem for perhaps a week or two, but once again it stopped working except for high speed. As the resistor module was quite cheap I bought another and fitted it, just to prove whether the prior replacement was faulty or not. The new one has done the same thing and stopped working on anything other than flat out after about two weeks.
Obviously the fault lies elsewhere, but I'm struggling to find information about the manual D8 setup - there is plenty around for the auto D9 ventilation. I'm measuring 12v at the main supply to the fan when the ignition is on but am not sure of the feed to the 4-terminal plug Does anyone have any ideas please?
Thanks.
Thanks.
