I Have a 1990 S1 405
Can anyone help here ? I'm going thru the process of trying to get it to idle at the correct RPM.
Currently minimum idle is 1000rpm - when cold - even with the Supp Air Device blocked off, but when hot goes to 1300.
Supp Air Device has been cleaned and 12v seems to close it after about 5 minutes. So I'm assuming it's OK.
But I can't locate the Manifold Absolute Pressure ( MAP) sensor.
Haynes manual says on the "right hand side valance"..
Does it connect to the manifold via a hose or is it actually screwed into the manifold ?
Where too from here ?
