405 bottom radiator hose
John505
Morwell, Victoria, Australia.
You may recall that 405 radiator hoses had that screw type fitting to the radiator instead of a metal clip as most cars do. I wonder if a lower radiator hose that has the screw type fitting and is said to be suitable for the XU10J2 405 would also fit the XU10J4 as fitted to the Mi16? I am not aware that there was a difference between the J2 and J4 engines in regard to the radiator screw type fittings but maybe there was? Can someone provide an opinion on this please?
John505
Different part nos, 8V & 16V but look similar. Radiator end looks the same so it'll depend on the thermostat end.
