hey guys, whats the easiest way to bleed the clutch on a 69 404 that is completely empty. cheers
with the 504,s we used to put the plastic tube on l/f brake bleeder nipple and crack until fluid is at end of hose then put hose on clutch bleed nipple and open bleeder,check brake fluid level and then slowly push down brake pedal this will pressure bleed back through clutch slave and master cylinder and ito shared reservoir.you could use same method to pressurise 404 but as has separate resevoirs would have to keep eye on brake master cylinder level and clutch reservoir overflow and depress valve at top of clutch slave cylinder........just an idea........jimIf you can obtain the assistance of a helper , get a large syringe some plastic tube , crack bleed nipple and while the assistant holds the little vale in the master down inject the fluid from the bottom.
