i have posted in the parts wanted forum but thought i'd put this here coz i need a little help / advice on various things.
I've been working on the Pug for 5 months or so, some members have been a great help with parts and advice. Thanks..
- the windscreen rubber trim. How the hell do you get it back in? Any tricks?
- today having most of the exterior back together I thought i'd take her out on the road for a spin.
But I had the same problem as when I first got the car.
On releasing the clutch in 1st gear and trying to move off there is a lot of shudder and the car almost stalls , i have to keep the revs up but i can't get it to go up my steep driveway (see in pic)
There is also a bit of a whine noise at idle which goes away when the clutch is engaged.
when i first drove it (on flat ground) if i got into 2nd gear quickly it would drive fine.
Any ideas welcome........
Apart from that. the engine starts and runs quite well.
I did a lot of work on the body, far from perfect, then painted the top black and the bottom a dark grey,
polished all the trim, lots and lots of other little things as well.
- Still have to get the washer pump working.
- Redo the door linings.
- Haven't been able to get the bonnet to drop in and fit tight on closing, the end near the windscreen sits up too high.
